2007 f150 cranks no start and no codes
i have 2007 f150 3v 5.4l XLT .. i drove my truck Saturday and parked it overnight and the next day I jumped in It to go to the store and it would not start ..it cranks over but no start ..I changed the...
-coil packs
-spark plugs
-fuel module
-new battery
-new key for ignition
-fuel filter
-fuel pump is good
-coil packs
-spark plugs
-fuel module
-new battery
-fuel filter
-fuel pump is good
The only thing I can really think of that might be causing this would be the fuel module misreading. Maybe even reading that theirs no fuel. Did you install the fuel filter properly? When I put a new one on mine the spring broke on the lock that slides onto the fuel filter so it pop off every 4th or 5th time I would go to start my truck and it would constantly crank but wouldnt turn over hope this helps
I did put the fuel filter correct no issues there...I used starting fluid to get it to start and it started right up and stayed on! It shacks a little bit but I think i just need to clean the throttle body..I also used STP fuel injection Cleaning system(Black Bottle) it worked great I haven't had any problems since. So the problem was dirty fuel injectiors.There weren't bad, so im assuming thats why it wouldn't give me a code or Engine Light
