5W20 or 5W30 conventional oil
#46
http://en.wikipedia.org/wiki/Corporate_Average_Fuel_Economy
I bet I could sneak into your garage during the middle of the night and change your oil to 5W30 and you would never know. And, your engine wouldn't either.
#47
CAFE fuel economy regulations were defined for trucks in 1979.
Corporate Average Fuel Economy - Wikipedia, the free encyclopedia
As far as changing the oil in the middle of the night, probably right, I would not be able to tell right then. However down the road if I kept on using it I am sure I would regret it, as I did with the 98.
#48
Just wanted to share some info from a couple of Ford's Service bulletins:
TSB 01-4-7 actually mentions the reason 5w-20 in now recommended.
"ISSUE: Engine oil recommended for use in 2001 vehicles is SAE 5W-20 motor oil. This oil has an improved formulation to improve fuel economy."
Same thing when they switched from 10w-30 to 5w-30 a few years ago.
TSB 99-8-16 recommended that most engines use 5w-30. The reason being:
"Tests have proven SAE 5W-30 viscosity grade motor oil provides the optimum protection and benefits for Ford gasoline engines. At both high and low ambient temperature conditions, SAE 5W-30 provides the best overall protection. It allows faster starts under cold ambient temperatures.
SAE 5W-30 also provides approximately 1/2% increase in fuel economy over SAE 10W-30".
I've got 13 cases of 5w-30 stacked in the garage. I think I'll stick with it.
#49
Your statement is meaningless. As I said, CAFE was unchanged from 96 to 2004, so there was no need to change oil for it, nor redo the specs for earlier years. They made the change for a reason, and it wasn't CAFE.
When I can't find the oil I prefer at each OCI in 5W30 I use 5W20.
Would it offend you if I used 10W30?
#50
And, great choice on the 5W30.
#51
#52
#53
#54
The OP has a 4.2 V-6, which is an old tech pushrod motor. You can put just about anything in one of those and not hurt it. All you guys chiming in with OHC V8's are trying to compare apples to oranges. I have a friend that puts 20w50 in everything he owns and he has never had an oil-related failure.
