2004 5.4 #4 plug removal
Old 01-22-2012, 08:16 PM
doehnter's Avatar
Got all 7 out after they all broke. Number 4 is stuck. Lisle tool wont screw into it. Perhaps because of not enough space. Any ideas?
Old 01-22-2012, 08:51 PM
wrenchbender's Avatar
i had a couple that I had to bust some of the ceramic off with a long taper punch that was ground to a chisel point. Blew out the chips with a compressor. There was too much sticking up (out?) to get the tool started.
Without looking, hard to tell what you have, have only done my 8-limited experience.
Old 01-22-2012, 11:44 PM
Blang's Avatar
Try using the pusher again to re push ceramic down farther. I have had to do this before. Also try to apply downward pressure while getting tap to initially bite.
There is plenty of room on plug 4 if you remove computer and bracket.
Old 01-23-2012, 07:49 PM
doehnter's Avatar
Confirmed for the third time that it was pushed down all the way. Still no screw. Called Lisle and he said to get a 1/4" hammer drill 8" long. Did that and measured carefully. Nada again. Tomorrow is my last chance.
Old 01-23-2012, 10:31 PM
transfercase's Avatar
Here is what I did when I had the similar issue:
https://www.f150online.com/forums/20...g-problem.html
Old 01-25-2012, 05:54 PM
doehnter's Avatar
5 days to get all 8 out. Cleaned throttle body before first firing it up today. The thing runs like ****. Got codes P0102,P0354,P2106 and P0113. Only had a slight miss before the plug change
My question is this. I put dielecric grease in the coil area where the plug plugs in. Can this cause this much of a mess? Truck misses bad and goes into safe mode.
Old 01-25-2012, 06:00 PM
doehnter's Avatar
The reason it took so long to get number 4 out. The Lisle tool went dull after 6 plug removals. I had to spend $80.00 on another then make a wedge out of 1"x4" to apply pressure as I turned it to get some bite. What a PITA.
Quick Reply: 2004 5.4 #4 plug removal
