Park Assist Problem - 06 FX4
Old 05-31-2011, 05:51 PM
My06Screw's Avatar
So the park assist on my 06 FX4 screw has worked fine since I got it [2 months ago] ... until last week. I pulled the neg terminal on the battery to turn off the SES light [rear O2 sensor - part on order] and once I reconnected it the problem with my park assist started.
Now, everytime I put it in reverse the "Off" light comes on. This didn't happen before I reset the PCM. Is this a huge coincidence or am I missing something? Is there something else I should check / reset? I searched but couldn't find anything on this. TIA
Old 06-02-2011, 07:01 PM
My06Screw's Avatar
Anyone ???
Old 06-03-2011, 12:02 PM
Have you checked your owners manual?
Fuse?
Sensors?
Connections?
Module?
Old 06-03-2011, 03:02 PM
Assuming it is related to pulling the terminal I would check the manual for the fuse related to park assist and check it.
If unrelated see list above.
Old 06-03-2011, 05:03 PM
BlackHD06's Avatar
take a look at the powerstroke.org (i think) website. There is a good write up about checking and replacing the sensors.
They are all linked together so if one goes they all quick working. Typically if you swap out 1 another will go out in a month.
Quick Reply: Park Assist Problem - 06 FX4
