anyone know anything about ride height adjustment
so i know you guys are sick of answering my questions but this one has gotten to me.
truck always measured a quarter inch lower on the driver side. front and rear
put on an as 1.5 and got it aligned. no blocks in the rear
for some reason my front right is cambered out some, and alignment shop says i need a cam bolt for the bottom strut mount to correct it.
now the front driver side measures to a 1.5 inch lift. its right at 38.5 inches. it was 37 before.
the front passenger side however measured 37.25, and now it measures 39 (thats a 1.75 inch lift out of a 1.5 spacer).
my front passenger side is a half inch higher in the front.
the rear has always measured 38.75 driver side, 39 passenger side.
i dont think im being picky. isnt something wrong if one side of my truck is a whole half inch higher than the other side? it looks perfectly level when looking at it from the passenger side, but if you look from the driver side it looks raked a little still.
so to sum it up right now my measurements are
front driver 38.5
front passenger 39
rear driver 38.75
rear passenger 39
this is the alignment sheet
is the shop correct when they say there is no camber adjustment without getting a cam bolt?
only thing i can note that is different is the slots where the upper strut mounts to. the 3 holes are slotted. they are maxed out to one side on the driver side, but the passenger side they are in the middle it seems like.
what does rotating the strut do to the truck? they have to do something, otherwise ford would have just made 3 holes for it to mount to, not 3 slots.
anyone know? i just want to bring the front passenger down that half an inch.
tires are pretty even pressure all the way around and ive measured it on a few different surfaces.
front driver 38.5
front passenger 39
rear driver 38.75
rear passenger 39
hand tighten down the top three nuts and put a steel rod (like a 1/2" socket wrench) through the bottom strut hole and twist, which still requires some effort. I bet if a survey was done on measurements from one truck to the other, lift/no lift you would get similar results in height differences. If your truck is tracking right and tires are wearing evenly it may not be an issue other than you know it's off somewhere. Have you done any measurements from center of wheel/hub to the bottom lip of fender?
front driver 38.5
front passenger 39
rear driver 38.75
rear passenger 39
The caster and camber is adjusted with the mounting bolts that hold the lower control arm to the frame..they are off-center bolts for this purpose. Any kind of "cam bolt" would never do anything here.
It won't do a thing..the strut assembly is a certain length and trying to turn it will be a project (totally loosening the three bolts and removing the large mounting bolt and turning the strut with a bar or something..I can't see what you will gain from that either.
Have you owned the truck since new ?? Just wondering if it may have been in an accident at some point...(frame problems) ??
The alignment spec sheet looks good !
front driver 38.5
front passenger 39
rear driver 38.75
rear passenger 39
