Window Regulator new assembly,The up & down is Reverse.
Old 07-19-2010, 11:50 PM
TX4X4's Avatar
I Replace My Window Regulator on Passenger side with new one from ford dealership and the up and down are reverse at switch, The Old pig tail and the new to motor that came with new assembly are the same.
Are these new regulator from the ford dealership reverse also like the aftermarket assembly they say.
Is there a short pig tail out there to solve this reverse problem?
This new window regulator for passenger side Part#(WLRA-38,4L3Z-1823200-CA regulator)Ford Motorcraft.
2004 FX4 OFFROAD.
Old 07-20-2010, 12:21 AM
f150dan's Avatar
Just reverse the two wires. Problem solved.
I had the same problem when I rplaced the window motor on my '97 Powerstroke. I just switched the 2 wires and it has worked great ever since
Old 07-20-2010, 12:23 AM
ford norseman's Avatar
^ x2. Somebody on the assembly line put the wrong wires in the sockets of the connector.
Old 07-20-2010, 02:15 AM
TX4X4's Avatar
2004 FX4 OFFROAD.
I did not want to cut any wire to make the swap so,
I got one end of the pig tail to swap wire, at the black end was the easy one, Removed red locking clip inside,by pressing a hole at back & then push it out.
and to release the wire pry up on black clip inside at far back to release while pulling wire,
Make your switch,
Then put red locking clip back in.
I used a small straight o-ring pick.
The cable used is the short pig tail that came with the new assembly to motor, or you can use your old one. The other end of pig tail is gray it goes to the motor.
This could of been a lot easier if the cable was wired correct the first time.
Old 07-20-2010, 05:41 AM
svt2205's Avatar
Who manufactured the assembly you installed?
Old 07-20-2010, 06:17 AM
ccecilm2's Avatar
At one time they were made so you could insert a small screwdriver into the back of the plug (where the wires enter) and it would release the latching mechanism for each wire so you could pull them out of the plug and switch them. They would come out with the metal end intact so you could just push them back into the other side.
Old 07-20-2010, 11:45 AM
Huitt24's Avatar
This happened to me twice. Once on my wifes 05 passenger window using a Ford part and on my 04 using an aftermarket part made by Dorman. You can use a small screw driver and release the locking tab on the pins in the connector and just swap postions, takes a couple of minutes but it works just fine.
Old 07-20-2010, 12:21 PM
XPerties's Avatar
Take it back and get a different one :o
Quick Reply: Window Regulator new assembly,The up & down is Reverse.
