Replace map light in front of sunroof?
Old 05-05-2010, 09:24 AM
kbutton1's Avatar
I just noticed my driver's side map reading light (the one in the headliner you push on the lens to activate) must be burnt out. It looks like a fairly simple bulb replacement, but I thought I would ask around to see if there are any pre-cautions that need to be taken when replacing this small lamp inside the lens.
I don't like tearing plastic molding off unless I ask about the procedure first.
Both lamps have a plastic ring (molding) surrounding the lenses and there is a sunroof switch between them.
Looks like I need to pop the plastic ring off and then look inside to determine how the lenses/lamps come out so I can replace the driver's side bulb.
Any suggestions would be appreciated.
Old 05-05-2010, 09:33 AM
fivespeedsteed's Avatar
interested too. someone help us out
Old 05-05-2010, 10:00 AM
SoonerTruck's Avatar
The whole assembly should pop down and allow you to change the bulb. It isn't any different on a sunroof-equipped vehicle I don't believe.
Old 05-05-2010, 10:58 AM
ChrisAU's Avatar
Yeh, the entire assembly comes down from the roof and the bulbs are accessible from the top.
Be careful when pulling/prying though, don't pull down too fast because you will pull the wires. The bulbs just twist out.
Old 05-12-2010, 08:38 AM
kbutton1's Avatar
Perfect. I found the bulb wire was not making contact. So I rest the wire and it now makes good contact and works fine. Thanks for the advice.
Old 05-12-2010, 08:39 AM
kbutton1's Avatar
"reset" not rest
Old 01-09-2013, 06:15 PM
3blkcats's Avatar
2006 F150 map light bulb replacement w/ sunroof
Here is the info you need to replace the map light bulbs in an 06 with a sunroof. ronscarcarellc.com
Old 01-09-2013, 06:18 PM
3blkcats's Avatar
I realize that this is an old thread, but since there was no help posted, and some of us are just now running into this....Here is the info you need to replace the map light bulbs in an 06 with a sunroof. Tip of the Day 2006 F150 http://ronscarcarellc.com
Old 01-09-2013, 06:20 PM
jdeacon's Avatar
did you join to bump a 3 year old thread lol
Quick Reply: Replace map light in front of sunroof?
