HELP! Hose stuck down dipstick tube!
Is it dangerous for me to start it???
Are you changing tranny fluid or engine oil?
The Oil has A (as in 1) plug. you pull and the oil drains. For tranny fluid, you pull the whole pan.
No hose needed for either, you got some bad info or you're screwin with everyone. To pull dipstick tube, there is one bolt holding it in. Remove it then tug on dip stick tube to remove.
You will be in my prayers.
