F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > F-Series Trucks > 2004 - 2008 F-150
SPONSORED BY:
Thread Tools Display Modes
Old 09-28-2009, 09:33 PM
Vehicle: 2004 Ford F-150
Throttle body removal/ cleaning
Hey guys I've been searching through the forum to solve my P0506 rough idle problem and came to the conclusion that I gotta clean the throttle body. I'm no auto buff and have very little experience working on vehicles beside changing oil, but everyone says it quite easy to clean...I just don't have a clue as to how to find,remove, and for that matter even find the exact part to clean. Any help would be appreciated, thanks.
Old 09-28-2009, 10:38 PM
Vehicle: 2006 Ford FX4
Remove your air box and clean it with some carb cleaner and shop towels. Or you can completely remove the TB and bench clean it. Just don't do what I did today and strip the MAF threads.
ΜΟΛΩΝ ΛΑΒΕ
Old 09-28-2009, 11:01 PM
Vehicle: 05' F150 FTX
im kind of like you... not a whole lot of experience but learning... I took mine off in a matter of 5-10 min. Hardest part was getting the clamps off of the air intake..
Just take off the clamps from your air intake, remove the 4 bolts.. can't rem what size.. maybe 10mm, remove the 3 plugs i believe.. and it will come right off... use some carb cleaner and a shop towel. Carbon should come off fairly easy. Just don't use anything that could scratch sides. Then just reverse to put back on.
Very easy to do.. I would say on a scale of 1-10, 10 being hardest as far as mechanically, this was about a 2
Sig done by Screen-fx.net
Quote:
Originally Posted by LoneRanger93 View Post
I like it, I'm always a fan of little touches like that, which will probably be noticed by 1% of the masses, but truck guys always pick up on it!
Old 09-29-2009, 01:19 AM
Vehicle: 2004 Ford F150
It sounds harder than it really is. I spent more time waiting for everything to dry off than I actaully spent removing and re-installing the parts. While you have the air intake off go ahead and remove the maf sensor and spray it too. I just went to the auto parts store and bought the stp throttle body cleaner (worked great) and some crc maf sensor cleaner. Remember not to touch the maf sensor but just spray it and thats all you will need.
Roush Off-Road Exhaust & CAI, Saleen Grill & Subwoofer Enclosure, Bilstein 5100's, HD 22's
Hella Blackouts, L.E.D. Tailights, & 3rd Brake Light, Brisk Silver Racing Plugs, Truxedo Toneau,
Polk DB571's, Troyer Custom Tunes, Powerslot rotors & Hawk pads all the way around
Sig Created By Dirty88 @ http://www.screenfx.ipbfree.com/
Old 09-29-2009, 10:08 AM
Vehicle: 2004 Ford FX4
Send a message via Yahoo to vtelvr
This may sound like a dumb question, but I am a bit gun shy about messing with my MAF. I had a 99 Explorer that ran with the CEL on for about a year b/c of intake issues.
If I don't have a light on dash showing that there is an issue, and my truck isn't showing any codes, would it be advisable to do this cleaning? I am afraid I could/would do more damage than if I just let it be. What say you?
Somewhere...between here and there
Old 09-29-2009, 12:49 PM
Vehicle: 2005 Ford F150
I haven't looked at the TB's on our trucks, but I do recall on my 95 cobra, the OEM TB had a sticker on the outside rim that said specifically not to use any chemical cleaners on the inside of the TB, as it would remove the buildup inhibitor on the inside walls. Does Ford still continue to do this? If so, using carb cleaner is probably not a good idea.
Old 09-29-2009, 05:55 PM
Vehicle: 2003 Ford F150 FX4
If there is already significant build up on the intake, is the inhibitor doing it's job?? I recently cleaned my TB and intake manifold using carb cleaner & Deep Creep and noticed a big improvement. If you don't want to go through the hassle, go get the motorvac service which will clean carbon deposits.
2003 FX4 Lariat SCrew, 5.4L, 3.73 Gears, 5" Rancho Lift & leveled, Edge Tuner, K&N CAI, MagnaFlow Cat-back Exhaust, American Racing 17x9 Alum. Rims, 35x12.5" ProComp Extreme A/T Tires
Old 09-29-2009, 07:33 PM
thanks for all the help guys. i actually just sprayed the area around/in the throttle body plate ( as directed by an autozone employee). Im just gonna let it dry overnight and then try it again with shanks12's approach. thanks again!
Gallery
Old 09-30-2009, 09:00 AM
Quote:
well, i don't know all that much about the coatings they used to use, or even if they still do use them. but i will say that in my experience, nothing is perfect. the inhibitor, if it's even still on the new ones, would just inhibit the build up, not prevent it. you guys do what you want, i was just pointing out what i knew about the old ones. maybe i'll check mine soon. how many miles on your rides when you cleaned them?
Old 09-30-2009, 09:19 AM
Vehicle: 2005 Ford F-150
At what miles is everyone cleaning there TB?
2005 F-150 4x4 XLT SCREW BLACK 5.4Scanguage II,Helo wheels,Nitto 325-60-18.HD grill,Westin boards,bedrug,Undercover tonneau, Weathertech mats,reverse senser,2-way alarm w/ starter,Xlt console,Magnaflow si/so, Infinity speakers,Billet cup rings,Avic-D3,Boyo camera,R1 rotors,Wagner ceramics,EZ down,Line of Fire,Staun air down,egr flares,Bilstein.
http://www.f150online.com/galleries/....cfm?gnum=8821
Old 09-30-2009, 12:48 PM
Vehicle: 2005 F150
I just rolled past 24,000 and cleaned mine. I was able to wipe most of it off with a paper towel. I had the shakes while sitting at red lights. I've only gone out once since I cleaned it and no shakes so far.
Is it possible the inhibitor keeps the filth from embedding itself into the pores rather than inhibiting the actual build up? Mine wiped clean without much effort at all, suggesting to me that the surface is fairly smooth. I'm thinking spraying it may lead to quicker buildup, more frequent cleaning - not that it's a hard job to do. Do whichever you're more comfortable with.
If a hammer won't fix it you got an electrical problem.
Old 09-30-2009, 01:15 PM
Vehicle: 2006 Ford F150 XLT
All you need is a socket wrench and a standard set of sockets. Very easy to remove. Don't get any liquid on the electronics on the side of the TB. What engine do you have? The 4.6's TB is easy to remove, but I have no clue on the 5.4.
2006 Ford F150 XLT - 281ci V8 - Regular Cab/Flareside - 2WD
True Dual Magnapack Exhaust - Gott's CAI - Edge Evolution Programmer
Mustang Exhaust Exhaust Interior Drive By
Old 09-30-2009, 01:28 PM
Quote:
I am just under 50,000 on mine. It was caked up pretty good also.
Old 10-01-2009, 08:28 AM
Vehicle: 2008 Ford F150
Can anyone post some pics on the removal or some pics of the airbox off then the TB off for a 5.4 ? Would like to do this as well and pics would make me more comfortable first, THANKS !
2008 Lariat Screw 4x4
Rousch Grill
ARE Hard Tonneau
WeatherTech Liners
Fusion Key Mod
Gryphon Tuner ( Custom Tunes by Bill )
Boss 20" Chrome Rims
Toyo Open Country AT 275/60/20
MagnaFlow Dual Exhaust
Kenwood DDX 7017
Kenwood Nav 4100
Kenwood 800 Watt Amp
JL Audio Speakers
Sirius Sat Radio
Ipod Interface
Tinted Glass
http://www.f150online.com/galleries/...cfm?gnum=11746
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
