Is there such thing as a 2-piece rotor/hub replacement?
#61
2wd hubs and rotors
All 4 rotors were warped at 30K service. They've been turned and are warping again <2 months of city driving.
This hub mod seems like the way to go. I hope I can find the kits in stock when I'm ready pull the trigger. If not, I'll be forced to go with the combo hub/rotor from a name brand that I can find locally.
I never would've known about the mod as well as all of the problems that everyone else is having w/ rotors/brakes. I think back to previous trucks that I've had... two F-150s and a full size Bronco... they all had similar brake issues.
Great forum!
Thanks to all who contribute.
Al
Great forum!
Al
#62
I just want the hubs and spindle nut .. I don't want there rotor. Do you know the part # w/o the rotor?
I just recieved my Hub/Rotor Kit from Rockauto.com.
I can now definetly tell you that 12065128 is the correct part number for the kit and not just the rotor. I recieved the hubs rotors and spindle nuts.
Kits costed me:
2004 FORD F-150 5.4L 330cid V8 FI (5) SOHC
CENTRIC 12065128 (120.65128) Rotor $ 138.79 $ 0.00 2 $ 277.58
Shipping Ground (FedEx or UPS) $ 31.81
Order Total $ 309.39
This is what the website description says:
CENTRIC Part # 12065128 Centric Premium Rotor
RWD; 6 Lug; Base Payload Pkg; Hub & Rotor Assy; New Model; To 11/29/04; UPGRADE KIT; Front
RWD; 6 Lug; Base Payload Pkg; Fr 11/29/04; Hub & Rotor Assy; UPGRADE KIT; Front
Kits costed me:
#63
#64
Hub only
This is from the rock auto site for a 2006. It looks like they have the upgraded hubs. I'm not sure about the bearing. Someone mentioned a shortage, so I'd do a stock check before buying.
CENTRIC Part # 12465902
RWD; 6 Lug; AFTER UPGRADE; Base Payload Pkg; Hub Only; Front
* Non-stock item--shipping delayed up to 2 business days
$85.79
Al
$85.79
Al
#65
I'm hesitant to buy the kit, but plenty of folks swear by it. It's "one stop shopping."
Al
#66
#67
Installed Centric 4x2 hub mod, premium rotors all the way around, and TQs a week ago. Did the "bedding" runs, and have taken it easy on the brakes. So far, so good. I notice myself really paying attention while braking and it's nice not having the "shakes" anymore.
Next project... broken drop-down bin, grill emblem, rear seat rattle, and odo back light. Maybe I'll catch up someday.
Al
Al
#69
Install is fairly easy. Take off wheels, take off calipers, remove rotors, remove center nut with a huge socket (I believe it was 36mm), slide off old hub, and reverse. You'll need to torque that center-nut to 300 lbs. (gorilla spec).
I just used these same Centric hubs on my brothers 4x2, but I used the Baer +1 15" rotors (for 4wd trucks) and caliper relocation kit (instead of Centric Rotors or Baer +1 rotors for 2wd). Baer has been using this same exact setup for some time, now. The 2WD Bear +1 15" rotor kit is a two-piece design as well.
#70
Kits costed me:
Kits costed me:
I have a 2005 Supercrew 4x2 with 7-LUG wheels.
My truck is shaking while braking during high speeds.
I already replaced my rear rotors but Ive been told by mechanics and Advance auto that I will need replace the whole hub assembly for the front rotors. IS THIS CORRECT?
If so, are there 7-LUG Upgrade Kits?
I cant seem to find any on rockauto.com and I would hate to have spend extra money on a problem that may happen again years later.
#74
#75
