Is there such thing as a 2-piece rotor/hub replacement?
#46
I need some help here. I posted my problem in the brake section with little response. I've gone through 6 rotor/hubs within a year...all due to bearing failures. Can anyone give more info about the reliability of this conversion?...especially those who've done it. Do the bearing keep going out on the conversion? I can't keep forking over money for this bearing issue...it's gotten way too expensive! I'm taking in my truck to Ford to have them give a look over and see if there's something else going on here like a spindle or something. I just can't see how this engineering could be so poor. Please help...replies, emails, IM's...anything!
BTW, my truck is an '05 F150 2WD
#47
Hey All,
I am in serious need of the centric rotor and hub upgrade for my 2004 f150 2wd. Every site that used to sell the kits has it listed as unavailable or does not list it at all. Does anyone know if this has been discontinued. I hop not. I don't want to put the oem one piece again. They don't last.
#48
Steve
I spoke directly to Centric twice about this upgrade. They told me that they were also having problems with the bearings and have redesigned the hub and are currently in production. The tech I spoke with sent an email with ETA to China and he replied to me that they're about 2 weeks out. It will be the same part number as before. 120.65128
Are you having bearing issues also??
#49
120.65128 2004 F150 2WD, a basic 2-piece replacement kit for the hub/rotor assembly b
Hi Abourda
Thanks for the Info. No bearing problems as of yet. Funny I just called centric this morning and the Girl that picked up wouldn't give me any more info than that they are out of stock and that she didn't know when they were getting any more. With the information you have just provided i'm thinking that it is a better idea to take it easy with my warped rotors for a little while and get the new design.
Steve
Steve
#50
#51
I don't think that part number is for the hubs. I think that part number is for rotors only. Can anyone confirm?
#53
This is what the website description says:
CENTRIC Part # 12065128 Centric Premium Rotor
RWD; 6 Lug; Base Payload Pkg; Hub & Rotor Assy; New Model; To 11/29/04; UPGRADE KIT; Front
RWD; 6 Lug; Base Payload Pkg; Fr 11/29/04; Hub & Rotor Assy; UPGRADE KIT; Front
#54
Just an FYI these parts are increasingly more difficult to find. The Hub / Rotor package is on indefinite backorder from Centric. After a half day of searching I found they can be obtained for 203 a side free shipping from brakewarehouse dot com. There are about 18 sets left. Might want to call to verify actual inventory before placing an online order. Apparently they are trying to source a new manufacturer and it's taking quite a while. I just got my set this week and on visual inspection it looks great especially the hub.
#55
120.65128 2004 F150 2WD, a Basic 2-piece replacement kit for the hub/rotor assembly
I just recieved my Hub/Rotor Kit from Rockauto.com.
I can now definetly tell you that 12065128 is the correct part number for the kit and not just the rotor. I recieved the hubs rotors and spindle nuts.
Kits costed me:
2004 FORD F-150 5.4L 330cid V8 FI (5) SOHC
CENTRIC 12065128 (120.65128) Rotor $ 138.79 $ 0.00 2 $ 277.58
Shipping Ground (FedEx or UPS) $ 31.81
Order Total $ 309.39
Kits costed me:
#59
i found this website for R1 brakes, but i cant tell if they're offering the hubs with the rotors or if you have to go find them yourself and then just buy their rotors. anybody try those guys?
http://www.r1concepts.com/blog/2004-...-brake-rotors/
#60
There is a document about this on Centric's website. Go to http://www.centricparts.com/ and hit the Tech Support tab at the top. Go to White Papers and there is a PDF document at the bottom of the third section "Technical Guides" for the F150.
