Is there such thing as a 2-piece rotor/hub replacement?
#137
#138
#140
Sounds like this is one of those "how to save money" solutions. The kit allows you to buy lower priced rotors. And anyone with economy in mind, is not installing this kit, then upgrading to using very expensive slotted, cross drilled, rotors.
With the 2WD, most of the problems come with trying to save money. Do not re-use the spindle nut. They are expensive, but you should not reuse them. Do not buy cheap brakes. Cheap rotors have cheap bearings. Cheap pads on cheap rotors will not stop as well.
I have found that the PowerStop brake kit works well. Stops good. No bearing failures. As for myself, I find the value in the stopping power. I don't care if the brakes cost more, if I don't run into a tree. I'll trim my budget and save money by clipping coupons at the supermarket and buying day old bread, if I don't run into a tree.
Click image to open expanded view
5.0 out of 5 stars Was:$606.75 Price:$557.98 Free Shipping for Prime MembersYou Save:$48.77 (8%)
Power Stop K1940-36 Front & Rear Z36 Truck and Tow Brake Kit
- Components are engineered to handle the stress of towing, hauling, mountainous driving, and lifted trucks.
- Dust-free braking performance.
- Z36 Carbon-Fiber Ceramic formula provides the extreme braking performance demanded by your truck or 4x4
- Premium stainless steel shims provide better heat dissipation for improved stopping power with virtually no noise
- Drilled and slotted rotors keep your brakes cool even in the most extreme conditions
#141
#143
I knew a guy with a muffler & brake shop. He got me everything at his cost from his distributor. Always Bendix & Wagner. I got a good price, and that was all that I cared about. Never had a problem with those brands. My cars always were able to stop, and I could resurface the rotors and just change pads. But the PowerStop kits are noticeably better On small economy cars, I never noticed the difference. After all, a Honda Civic isn't a performance vehicle (unless you have the right stickers). But with a 1/2 ton pickup, with bigger wheels and tires, and a full load or towing......the more expensive brakes are worth it.
#144
Check out brakemotive on eBay, they are power stop parts when you run the part numbers. Been using them for a decade on different applications and never have been let down. Having said that the rotor pad kits come with the z16 pads (not a fan) so I only buy the rotors and used the z36 pads on the truck
