Possible LS clutch packs Issue??
on
1 Post
I did my best to search for better descriptions of the symptoms related to the clutch packs, but my impatience got the best of me.
Anyway, my ’04 FX4 has been starting to “slip” I guess is the best way to describe it, when I slowly accelerate after making right turns mostly. It’s like the truck can’t find traction, but is on dry pavement. Once in a while when going up a hill or incline, the same thing occurs. Always seems to be when at part-throttle or slow acceleration. It does not seem to be the transmission, but who knows since I still can’t get used to the electronic catch-up it does at part throttle.
Is there anything I can do to diagnose the clutch packs? Or other specific symptoms I should look for? Besides an obvious trip to the dealership, which I would like to save for the repair if needed, since I like having a general understanding of what is going on with my truck prior to taking it in. Not that they would take advantage, but…
Thank you in advance for any and all information you can provide.
clutch
If you feel the "slip" while going slow and making your turn it's probably the clutch in the LS,, i also have a 2004 and mine did the same thing. Was a common problem with the 04,, took it in to dealer under warranty and he did not hesitate,,replaced the clutch pack, that was 3 yrs ago,, problem gone.. good luck.
on
1 Post
I have just turned 35,000 miles on it, and am getting ready for an oil change anyway I may try the fluid change. Sounds like the cheapest thing anyway. Anything I should look for while making the change of fluid? Discoloration or something like that?
The strange thing, is that it doesn't do it all the time, but who knows.
on
1 Post
Thank You
Thanks, I hope that a fluid change is what is needed.
I will dread finding any of the clutch or metal particle floaters when I drain the rear... Then I guess I will take my old fluid with me to the dealer for the replacement/repair of the clutch packs.
Thanks again for all the info!
same thing happened to mine, took it to the dealer they replaced the clutch pack an the limited slip, i guess i wasted the whole thing from pulling a 28' enclosed trailer on a snowmobile trip,every time i'd turn a corner pulling it , it would slam an bang,but it made it back home ,but tore it up pretty good.
