F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > F-Series Trucks > 2004 - 2008 F-150
SPONSORED BY:
Thread Tools Display Modes
  #31
Old 03-10-2009, 01:41 PM
Vehicle: 2005 Ford F150
I did a quick search by entering the words "porcelain glue" and came up with a bunch of threads. Here is one of them, hope this helps.
http://www.f150online.com/forums/art...porcelain+glue
Flowmaster 40, K&N dropin, Tint, Roush wheels, 305/50/20s
Edge Evo with PHP custom tunes, GF 2" shackles
  #32
Old 03-10-2009, 03:54 PM
What did you use to get the bolts at the top of your homemade tap to stay in place when you turn it in?
  #33
Old 03-10-2009, 03:58 PM
Quote:
If you are asking what I think you are, those are not bolts. It's one piece of allthread with nuts screwed down to different positions.
  #34
Old 03-10-2009, 04:06 PM
Wait, are you speaking of the porcelain tool or the original shank tap/extractor?
  #35
Old 03-10-2009, 04:36 PM
Vehicle: 2008 Ford Expedition
you get 2 nuts, and then jam them together. this will prevent them from turning on the threaded rod while you try to crank on it
2008 Expedition EL - Hers (Bone Stock)
2009 Mustang Bullitt - Mine (F'ing quick)
Currently deployed...see y'all on the flip side
  #36
Old 03-10-2009, 06:38 PM
Vehicle: 2004 Ford F150
Well, I ran up to Napa and grabbed the Lisle 65600 ford plug extractor. $93
It worked like a charm, I stuck a screwdriver in and snapped the porcelain. It broke flush with the top of the sleeve that is stuck down in the motor, then i used the tools as defined, first i used the tool to press the porcelain down to make room for the extractor to tighten in. The only issue i have is a small piece of porcelain broke off in three of the four i extracted. I am going to run up to the hardware store and get some small flexible tube to ductape to the shopvac and suck around on top of the piston. Then, just to make sure I am going to turn it over without any plugs in it hopping any fragments blow out the hole with the compression. hopefully it will be ok.
I was thinking about using the homemade unit seen here, but with broken plugs way in the back i just did not want to take a chance with problems, if it was out front only i would have make my own...
  #37
Old 03-10-2009, 06:42 PM
Good luck!
  #38
Old 03-11-2009, 09:30 PM
Truck runs purrfect....
  #39
Old 03-11-2009, 10:25 PM
Vehicle: 2008 Ford F150 4x4
Quote:
Originally Posted by risupercrewman View Post
That has to be one of the most inovative things that I have ever seen on this site! Congrads!.........
I think this one is good enough to earn 'Technical Innovation Contributor' under your sign on name.
  #40
Old 05-23-2009, 12:32 AM
Vehicle: 2007 Ford F-150
Well, I am in the middle of this mess right now and am getting more angry by the minute. I have gotten two out and broken four, 2 are still unknown.
I tested a fine thread 3/16 tap on the work bench and it will not work. Because the stainless sleeve is not the proper size for a 3/16 tap, you cannot get a fine thread tap to start, the course thread will only tap 2 threads because of the same reason. But, when the two threads are tapped and the all-thread is engaged it is pretty darn solid. This is why the rotunda kit uses a 9mm x 1.0 tap, but that all-thread would be a special order item.
Ok. so here is my question, I have had a failure not listed, the threaded sleeve has backed out leaving the entire porcelain in tact. What do i do now, do i put a screwdriver in there and crack it off? Also, on the normal failure when the porcelain fills the stainless sleeve, how do i get that out of there enough to run the tap in? Do i chisel it away with a screwdriver?
You should be able to reach in the spark plug well with some long needle nose plires and carefully pull the entire porcelain part out leaving just the sleave behind. Then use the 3/8 allthread trick.
-2007 F-150 XLT SuperCrew 4x4 5.4L 6.5' Bed
-Bilstein 5100's All The Way Around, Front set at 2" lift
-Gryphon, custom tuned by Bill at PHP
-AirAid CAI
-Flowmaster 3" Cat-Back with 50-series (thinking of changing to a 40-series or a Magnaflow)
-Wig-Wag Headlights and Tail Lights
-Line-X
  #41
Old 05-23-2009, 04:20 AM
Vehicle: 2006 Ford F150
Send a message via AIM to kingofkings Send a message via Yahoo to kingofkings
Creative.
  #42
Old 06-08-2009, 11:58 AM
Send a message via MSN to Robs4X4 Send a message via Yahoo to Robs4X4
Lightbulb Cheap Extractor
I completed my plug change with just over 46,000 miles on my 2004. I had one plug issue, which I resolved with my Craftsman extractors (#6), a 10mm socket for the extractor to slip into, an extension and some electrical tape to hold it all together. I lightly turned the extractor in with a ratchet and pulled the plug end out. Worked flawlessly and it was Cheap! Hope this will help someone.
Also I used a 5/8" spark plug socket to grab the plugs from the cavernous hole.
I have some pics in my photo gallery if needed...
2004 F150 FX4 Ext. Cab, Silver, 5.4 v8, 4x4, Automatic, 3.73, Soft Tonneau.
Finally added a K&N drop-in, 3" Pipe Gotts Intake Mod and Magnaflow Muffler.
Further Mods to come...
  #43
Old 06-08-2009, 01:58 PM
I have to stop reading all these darn spark plug threads. Now I'm real scared to do mine. Think I'll just "let her ride" until it starts running like poop or 100k miles. Whichever comes first.
  #44
Old 06-09-2009, 10:38 AM
Vehicle: 2004 Ford F-150
Send a message via AIM to jimmyv13 Send a message via Yahoo to jimmyv13
I have a set of these extractors and was wondering if they'd work for this, good find!!! I'll probably get after this sometime this summer....I feel more confident knowing there are a couple of ways I can fix the broken plug in my garage rather than taking it to the dealer. With my luck, I'll be the first truck with 8 broken plugs...
2004 F-150 SuperCrew FX4
Quote:
Originally Posted by birddog_61 View Post
Its also clearly documented that second hand smoke is harmless. Your thought process on smoking in general is faulted.
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
