Question about used Suspension Kit
I would stay away from it. And my reasoning is this....
For the longest time I wanted to put a leveling kit on my truck, but heard too many stories about ruined ball joints etc, so I stayed away from a leveling kit. And then I thought about a small suspension lift (something smaller than the 6" lift). And then I read about the 3" lifts and what I read said they cause even more extreme angles than the leveling kits. And I read alof of stories of unhappy people.
This is not to say that people arent happy with leveling kits, or 3" lifts, but having read so many stories of problems caused, I decided to stay away from them.
Just giving you something to think about.
Originally Posted by tardman91
If your truck is 2WD go for it, just be prepared to go through ball joints 2-3 times faster than normal. If your truck is 4WD I would steer clear because those lifts totally mess up all your angles.
Edit: Sorry, I did not mean to highjack the thread. If you feel comfortable with buying a used aftermarket item, then go for it. I personally do not like that idea because you never know what it has been through.
I have the Skyjacker 3" kit on mine. I havent had any problems with cv joint or ball joint failure yet.
If youre getting a hell of a deal on the lift, I dont think it would be a problem to install it on your truck
I've been looking for slightly used skyjacker 3'' lift kit. I happen to find one but my problem is it has 20,000 miles of use on it. Is this to much wear already or should I go newer.
