It was originally planned to only be pictures of the power wire route...
Turns out, I started documenting the whole audio system "upgrade," step-by-step and included some tips that could help in any install.
By "upgrade" I mean this----> It is the factory 6-disk in-dash changer w/MP3, with a hi-lo signal converter tapping into (not cutting wire) the foctory harness, running RCA's to a single aftermarker amplifier, which powers a single aftermarket sub. I will have the custom sub box (for a 12") built soon... and I'll share all of those details as well.
Anyway, I hope this can be of some help to any of you interested in a DIY simple install using the factory head unit in a non-heritage model '04 - '06.
aer you going to paint it or put carpet on it? It looks good tho
It is carpeted.
The carpet matches the Arizona Beige of the two-tone more than the OEM carpet inside... I just strectched and stapled so if/when I find a better match somewhere I can recarpet it to match.
IROC...great job man...can you tell me how or where you tapped into the harness to add the hi-lo converter? I didnt seem to see it in your pictures.
What sub did you use? Whats the power rating on it? If you could, would you send me a prive message or an email?
It was a simple Lightning Audio "Bolt" 10"... it is rated at 150 rms, with a max of 750... Sounds very good for the initial cost... I've seen them on clearance at some Walmart stores for $30 bucks! They have some with yellow faces, and a few with the silver and black faces.. same woofer...
It's something to consider that basically, since these are owned and operated by Rockford Fosgate, that these have much of the same qualities built in.
I did double check the config in my '06 by lining up an aftermarket harness and cross referencing... NOTE: The POWER side of the harnes has different colors on the OEM side, but the speaker colors were the same in the '00 Excurzzzzzz
