What size speakers?
Originally Posted by captain morgan8
what kind of speakers are you thinkin bout getting?
I'm confused anything you see there isn't 6x8 theres 6x9..
5x7 or 6x8 same size. Only size used by Ford that I can remember. Go here and input your model truck and it will tell you what speakers will fit with no modifications and some that will fit with a slight mod to your doors.
Crutchfield
Crutchfield
Crutchfield
Crutchfield
Originally Posted by RamSS/T
They are 6x8s. I went with componets in the front (6x8 woofer and a tweeter in the stock tweeter hole) and 3-way coaxials in the rear.
FRONT:
REAR:
FRONT:
REAR:
How much did you pay for the tweeters and would you recommend getting new tweeters? When I got my headunit I got 2 2way 6.5" DUAL(brand) speakers.. lol do these suck so bad that they aren't worth using?
You can find a good set or 5x7s orm 6x8s coaxials for $100. If you want to go with Tweeters then get a set of components for the fronts and Coaxilals in the rear. Component Speakers are A 5x7 woofer, tweeter and crossover that are seperate pieces and are around $150+. Coaxial are one speaker with all 3 built in.Components produce the best sound. Look at Crutchfield or CircuitCity.com they run decent prices for both
Like I said the fronts are component speakers....that means you have to have both for them to sound right. So they are only sold as a pair (with a crossover). I think they were around $200 (2 tweeters, 2 woofers and 2 crossovers). Unless you have an Audiophile system you don't have tweeters fromt the factory...just a hole where they would go. As for the DUALs....do think they are ok? If so then they are fine. If you haven't put them in yet I would try pawning them off on one of your friends and either get better quality speakers or leave the stock ones in (IMO the stock ones would be better than those).
I mean Idk I wanna use these speakers for something but if the stocks are better lol.. I'ma prolly get some pioneers this summer for my birthday..
Go with the Pioneers...they are fairly in-expensive (notice I didn't say cheap...the quality is good), sound good and handle decent power.
BTW...you can get a set off ebay a lot cheaper than you can from even WalMart.
