Automatic Transmission Fluid Leak
Old 11-29-2005, 02:13 PM
wernst's Avatar
Went to have my oil changed yesterday and the serviceman pointed out that my automatics transmission fluid was barely registering on the stick. I verified what he said when I got back home. Had to put 1/2 quart to get it back in the normal hot zone. Anyone had this problem and what was the fix?
Old 11-29-2005, 02:21 PM
CarlJ's Avatar
Do you visibly see a leak? Just because it is low doesn't mean it's leaking, it could of just not been filled up to begin with, ford's quality control isn't always on top of things. However, mine had a leak at around 3000 miles. It was the seal on the front pump. It was leaking out of the torque converter housing vent.
Old 11-29-2005, 04:44 PM
wernst's Avatar
No visible leaks anywhere. Level comes up to the first dot on the stick.
Old 11-29-2005, 04:51 PM
asinatra's Avatar
When you checked it the vehicle was running and both engine and transmission were hot ?
Old 11-29-2005, 05:14 PM
Lumadar's Avatar
My truck had a leak BRAND new with red fluis all over the bottom of the truck... had to get a flange replaced or some crap.
Quick Reply: Automatic Transmission Fluid Leak
