Squeaky Rear End
Squeaky Rear End
I have a squeaky rear end. Every time my suspension travels or articulates it creaks. Im assuming that it is from dirt in my leaf springs? or could it be my shocks? How should I go about fixing it? If it is from dirt in my leaf springs, Im thinking of jacking the truck up on the leaf spring buckets, taking my wheels off, and giving the leaf springs a good cleaning with the pressure washer. Any suggestions? I know this isn't a lot of information to go off of but can anyone help? Im getting real tired of having to turn the radio up real loud.
There is a tsb out there for this. When they replaced my front rotors, they also lubed up my leaf spring packs. They put grease where the teflon pads met the springs and also where the U shaped pack hangers hold the springs together. They also put some grease on the front coil down where it meets the shock base plate. The grease lasts about 6 months then it starts squeaking again.
Ok, I've dealt with this issue from day one of picking up my truck. It's been "repaired" 3 different times, kept coming back slightly different. Oddly enough, I finally solved it the other day (so it seems) by myself. So I'll iterate through what they did and what I did. Each time they fixed it, when I picked it up, it was fine for 300-500 miles, then started squeeking again.
- Dealer Try #1 : Replaced "ear mounting tabs" for the tailgate.
- Dealer Try #2 : Found SSM 17777, greased rear leaf springs.
- Dealer Try #3 : Ordered new tailgate latch kit (supposed to install tomorrow)
- My Try #1 : Installed Bilstein shocks as part of my leveling kit, rear squeek is gone.
There was nothing that looked odd or "caked" up that could cause the squeek so maybe it was the shock eyelets, or something. Final result, replacing the rear shocks fixed mine, and mine had been an ongoing issue for a few months. Hope it continues NOT to squeek.
Yes, sorry I looked for this thread, but didn't find it earlier. The day before taking my truck back in for more service, the squeek came back. It was different though. At that time, my service advisor told me they'd look into it again. Turns out they replaced part of the tailgate assembly (probably the latch assembly) and it hasn't come back since then. I'll see if I can find anymore info out from my service record -- this last fix was quite a while ago and not a hint of a squeek.
Did the dealer write down what part of the tailgate assembly they replaced?
mxtruck
My tailgate on my old 2000 Scab squeaked and my 2004 Screw does the same thing. I just spray a couple of squirts of some all purpose lubricant on the the latch assembly inside the tailgate and it stops squeaking for about 4 to 6 months and then it squeaks again. I spray on some more lubricant and it stops for another 4 to 6 months. Granted it's only a temporary fix but it's the best fix I've found.
