Fuel Cutoff Switch!!!!!!
im probably wrong but, i think maybe our trucks is one that doesnt need to have its fuel pump turned off. it says in the superchips instructions "some viehicles may need to have there fuel pump disabled. in the trucks owners manual, pg 193 it describes the fuel shut down switch. if you read is says that we dont accually turn the fuel off, when something happens to the car it turns off automatically. the switch is just to reset the pump. i went ahead and programed my truck, no turning on or off the fuel pump, it works just fine and i can totally tell the differance.
i edited everything accept the shift points and the shift pressure, i wouldnt know what im doing if i tryed. has anyone who knows there stuff found some good points and pressure to use with the high preformance tune. just wondering, thanks alot i hope my explaination helps
Kudos to my salesperson...he wouldn't let me leave the lot until I pressed the reset fuel shut off switch. It's almost impossible to see. Looking at the fuse box, the reset switch is towards the top-left corner, behind the fuse box. It's like a little black rubber nipple....hehe... I said nipple
