PCM Codes
Old 04-02-2004, 09:14 PM
TrukMupper's Avatar
Grim,
You may not need to regret it. Mine is BME7 and I haven't had any of the problems associated with the software.
  #32
Old 04-02-2004, 10:21 PM
DaleF150's Avatar
Build date was 09/03, the code on the PCM is HVS8. I had the truck serviced about two months ago in begining of February and they were supposed to have updated the PCM.
I want to add that I do not think the temp is working properly. I have gone out to truck in the afternoon and the outside temp is at least in the high 60's and the truck shows 52 degrees. It takes about 10 to 15 minutes before the temp starts reading correctly.
  #33
Old 04-03-2004, 09:31 AM
Grim's Avatar
Originally posted by TrukMupper
Grim,
I'm not worried about the computer, I'm more worried about the mechanical problems that are cropping up on the early trucks that Ford has since corrected.
Grim
  #34
Old 04-03-2004, 09:33 AM
Grim's Avatar
Mine was doing the same thing, except it was taking closer to 30 minutes. The flashed my PCM, it seems to have fixed it.
Grim
  #35
Old 04-03-2004, 10:15 AM
YellowFX4SCrew's Avatar
Build Date: 09/03
PCM code: BME8
  #36
Old 04-03-2004, 01:48 PM
Wolfman064's Avatar
Build Date 9/03,
5.4 Supercab 4x4
PCM: HVS8
  #37
Old 10-13-2004, 07:57 PM
jpdadeo's Avatar
My build date is 9-03 and my original PCM code was ACB7
May 10, 04 my PCM was re-flashed when a #4 coil wire was repaired. I didn’t know the new code because the dealership didn’t indicate what it was on the invoice nor did they give me an “Authorized Modification” sticker. Today I was at the dealer getting an oil change & tire rotation, and asked if they could read the code and give me a sticker. No problem, took about five minutes to do. The new code is important to me because I am anticipating getting a “9100 Superchips Custom Micro Tuner” when they are released for the 04’s.
My new code is 4U7A 2B (I think) here’s a pic of it
  #38
Old 11-14-2004, 08:58 PM
Justis01's Avatar
Build date for my '05 Lariat is 10/04.
5.4L PCM: TEM5
Scott
BTW: No throttle lag problems. Hit the gas and she goes!
  #39
Old 11-15-2004, 08:22 AM
bobbydee3's Avatar
Build date= 03/04
PCM code= EAY2
5.4 3v XLT
  #40
Old 11-15-2004, 11:32 AM
spc's Avatar
spc
spc is offline
Build date 08/04
  #41
Old 11-15-2004, 11:52 AM
nightmoves's Avatar
04' Lariat Build Date 8/04 PTN4
  #42
Old 11-15-2004, 11:55 AM
HamRadio's Avatar
Heres a new one for ya
My build date is an early one, 07/03
Original version is KEN2
Not whats in it now......
  #43
Old 11-15-2004, 01:24 PM
cavenaugh's Avatar
May 2004
5.4L FX4 Reg Cab Build Date 05/04 PCM EAY4
No issues to report 6700 miles
  #44
Old 11-15-2004, 10:47 PM
Serge's Avatar
my PCM code is EAY4. if someone tells me where to find the build date i will post it.
  #45
Old 11-15-2004, 11:16 PM
jpdadeo's Avatar
Look on the white sticker on the bottom of the door pillar, driver side. The build date will be there.
Quick Reply: PCM Codes
