Heater control questions
Ok Gents here are the details:
-2003 F150 XLT FX4 Super cab 5.4L 4x4
-Manual A/C heat, 4 position fan speed switch
-symptoms:
the fan works both on heat and a/c, it also runs in all positions However in the position just before HIGH the speed varies. If I wiggle the switch the speed will pick up.
-I know 90% of the time the resistor can be the cause of issues with fan speeds, but this has me scratching my head. I am thinking it's the switch itself mainly because if I give it a wiggle it will go up to correct speed.
-What do you think?
-symptoms:
-What do you think?
