Remote Door Lock/Unlock
I have a 97 F150 with factory remote door lock/unlock functionality. For several years, I've dealt with the truck not wanting to lock with the remote until the engine has been shut off for about 30 to 60 seconds. This usually means I've gotten out of my truck and walked half-way into a store before the horn honks to let me know the doors locked. Once that time has passed, I can unlock/lock as expected. I've replaced my remotes and batteries and it's not a remote issue. I've replaced the RAP module and reprogrammed it and the symptoms are exactly the same. Any other ideas of what may be going on?
Thanks,
Ron
Thanks,
Ron
As indicated, it's a factory system, not aftermarket, and uses the stock ford remotes. I ordered this truck new in 1996 and specified every option it has. It used to work perfectly, but over the years, this issue has only gotten worse. It's not dealer installed!
Lots of people come in here saying their stuff is OEM and then post up a pic of aftermarket. Good luck getting any help with that attitude.
Read up on the GEM. That is where your initiation is developed. You have a GEM problem. I am a regular poster on another site, and have many years of Ford parts/service and warranty under my belt. I forgot about being a member on here, and since no one wanted to answer, I did. Note: GEM is number specific, so order correctly if you have to get one.
Ron
Ron
