2000 F150 V6 crew cab 2x4
Hey guys. New to the forum and F150 family. I have an 87 mustang, so trucking is new to me lol.
Question is, I have a 6400 lbs camper to pull around my area, wondering if it would pull it. If not, would would be ideal to make it happen. Keep in mind, im not wanting to win a race, but not wanting to be on fire every time I leave.
Specs as I know:
-2000
-Little bench in the back so Im sure it's not a reg cab.
-V6
- gear ratio im not sure. I just know it doesn't have much punch.
- 2x4
First truck<br/>
try the etis site
http://www.etis.ford.com/vehicleSelection.do
it will show what trans and rear axle ratio
if it doesn't work, pm me your vin, I will try it for you.
900 lbs over.. Which isn't that bad. I guess I'll see what I can invest in to get that extra punch. I got extra 5.0L parts lol... That's too bad.
Thank you very much for the help.
I'll stick around the forum. I'll get good feedback by reading the threads!
Fixed with added emphasis.
If you live in Kansas or Nebraska, you might get away with it, but any hills will likely be a big struggle. My '99 5.4 with 3.73's protested pulling 5,000# out here in Colorado. Towing 4500# back in Ohio was okay, but even then I had an F250 transmission cooler and was glad I did.
Andy
P.S. If you're going to try this, get a brake controller! I'd recommend a Prodigy P2.
P.P.S. - I'm assuming your truck already has a Class III hitch and 7-pin trailer connector?
P.P.P.S. - Do you have a weight-distributing hitch setup for the trailer?
Andy
