Tensioner pully broke, pully ground a small opening where mounted. Help
Hey guys . coming from St. Pete Florida . I'm shawn. Need some info. So the other day started to hear a small grinding noise from what I thought was the bearings in the AC compressor. But once I started digging around. It's was the tensioner pully bearings where shot. After removing the tensioner arm. You could see where the pully actually ground a small hole. Where it was touching the area it was mounted to. I didn't see any fluids leaking once I out things back together. And drove the truck. Anyone help me not worry. Is that mounted where the oil is? Should I worry that there is a hole in the area right behind where the tensioner pully faces the engine?
I want to say I'm no.mechanic by any means. But this sight has been an amazing help to me. In saving.money. and keeping this old work truck rolling. So a big thanks to everyone here that helps us not so mechanically include people out there.
It is a 97 f150. V 8. 4.6. It sure looks like it went through in a spot. About a half inch or so. But don't see anything coming out. Already thought about the JB weld. But before taking everything back off. Wanting to get more thoughts on the issue. Still can't believe that pully cut that so fast
