Truck idling OK stalls when stopping or going down a steep hill
Hi guys I have a 1998 F1 50 has a V-8 engine 4.6 L it idles OK and park by soon as you shipped it to drive or a verse it seems to idle little bit lower which is expected the problem I'm having is when I'm going down a steep hill or decelerating quickly it will either idol extremely low or install out trying to figure out what this is going to be a vacuum leak I've already cleaned the mass airflow sensor and the IAC this truck has an automatic transmission any help is appreciated
Ok so I found them 2 questions first do I take the throttle body completely off or just spray the hole that you see after disconnecting the elbow
Second should I use mas sensor cleaner in the elbow or should I use carb / throttle body cleaner
Anyways thank you, I cleaned the throttle body and sensor that was in the elbow after the mass airflow sensor. This seemed to do the trick it doesn't stall while Going down my driveway anymore.
I did find one other problem though when i rev it high i hear pops and the truck rattles my father seems to think that it's backfiring. The spark plug wires keep comming loose they don't pop completely off but enough that you can pull them off easily with one finger. Also when going 60+ mph it gets worse and the check engine light flashes
http://m.advanceautoparts.com/mt/shop.advanceautoparts.com/p/permatex-dielectric-tune-up-grease-09980/7730006-P?searchTerm=spark+plug+compound
What do you think Is this valid info. REALY DONT WANT TO CHANGE PLUGS AGAIN SUCH. A PAIN !!!!!
Even though Autolite plugs are made to "fit" the engine, they are known to have possible performance and durability issues.
Dielectric grease should always be used SPARINGLY in the spark plug boots. If the wires don't "click" when installing them on the plugs, you have crappy wires or they aren't fully on the plugs.
If you recently changed the plugs, pull the wires and use a TORQUE WRENCH on them - 28 ft/lb. If the wires are old or some cheap offbrand, REPLACE them.
