accelerating problems
my 2002 f 150 will occasionally have a problem accelerating when I first start it up. At times it will work perfectly. Other mornings it will sputter and drop RPM's as if the automatic choke is stuck and it's being flooded. It will idle but cut out if I try to accelerate. I have tried to set the choke before starting. No difference. I have tried to start it without touching the accelerator pedal. No difference. If it starts up OK, it will run all day without a problem. If it starts badly, it seems to have to sit a day or two before I can try it again. Any ideas. Thanks
accelerator problems
I'm aware that it is injected and not carbureted. I was trying to explain the problem by relating it to similar problems some "old timers" may have experienced in older cars. I have owned the truck for 6 years. The problem has just recently started. I always start the truck by just turning the key. No problems in the past. If i go through the same procedure now, it runs badly. it feels like a fuel problem. Pump, injectors or sensors. I looked at this forum thinking it's happened to others. Hate to take it into a garage and get charged a huge sum for simple fix, on a 13 year old vehicle. But it looks like that's the way it's going to play out.
