Clutch Bypass
Clutch Bypass
I have an 03 F150 with the 5speed and I'm wondering if anybody has bypassed their neutral safety switch, aka not having to use the clutch to start the truck. All the forums only have it for pre-97 f150's. So I'm wondering will it apply for mine or not since the 92+ have the Mazda 5speeds I believe. I want to do it for off-roading and such.
Thanks!
Thanks!
The switch is under the dash on the clutch actuator rod. You have to take the cover off to remove it. It just snaps together or apart. There is a connector with up to 6 wires coming out of it or 3 pairs. If it's an XL with no options like cruise there will only be 2 wires. I believe if you jump the two closest to the firewall you disable the safety the 2 in the middle are for cruise, probably don't want to disable that if you have it. If the 2 closest to the firewall aren't it, try the 2 closest to the driver.
Those six wires on the neutral safety switch
