Bushings (leaf springs)
I want to replace mine... To my knowledge they don't need to be replaced until they deteriorate (won't cause any damage until they deteriorate) but I don't want it to get to that point. They are starting to squeak a lot and every time I go over a bump or even jump into the bed of my truck they're squeaking. It's almost as annoying as the exhaust manifold gasket leak.
My grandpa used to be a mechanic and said it was always a simple process to replace bushings as long as you know what you're doing. I'd rather stay away from a suspension shop as much as possible so is it as easy as cutting the old ones off and using a lubricant to get the new bushing in? I heard about getting them pressed on too. If anyone has any experience with them, I would like some input. As I said, I'd like to stay away from the shops as much as possible. Thanks.
anything is possible......
just did this on my 01 with over 300k miles, had to drill out opposite ends of the bushings, then put a torch on it, big mallet and chisel to drive them out and a lot of wd40. Eventually they all came out and after cleaning the eyelets, I replaced them with some poly energy suspension bushings and put it all back together.
It would be a breeze if you have access to a press, there are a few videos on youtube that show how to use a threaded rod and an impact that just pulls it right out.
