Cluster Light Out
Cluster Light Out
Driving home from work and i started up the truck, turned the lights on and my cluster lit up fine, put the truck in drive and the cluster lights shut off, my cup holder light also went out, headlight, running light, day lights, turn signals all work just my cluster light and cup holder light went out any idea what it could be?
http://www.fleet.ford.com/partsandse...owner-manuals/
Download yours and read through the fuse charts. Looks like F18 in the in-cab fuse box needs to be checked.
Sounds like you have a short.
I don't know the best way to go about it, but I would use a multimeter to check for resistance to ground. When you find zero, you have a short.
You will need a wiring diagram and want to test on the hot side with the bulbs out.
Some multimeters have a continuity setting that may also work.
