Fitting 35s with a 2.5 inch leveling kit in front and 1 inch block in the back?
If you're 4x4, just crank the torsion bars don't buy a leveling kit. And because of how aggressive those tires are, even using stock wheels you'll have rubbing issues. You'd be better off with a 4-6" lift for those tires since you really need a 9-10" wide wheel anyways for them to wear properly.
If you're 2wd, you'll at the very least need a 6" lift. I ran the 305/70r16's nitto mud graps with a 6" lift on my old 98 2wd and still scrubbed a bit at full lock.
