Intermittent bringing noise not hubs not brakes
Old 03-25-2015, 08:40 PM
LTOFIGHT's Avatar
I have a 2001 f150 4x4. There is a noise, like a rotor grind, coming from the front passenger side area. I have changed the both sides; front hub assembly, rotors and pads, both rear axle bearings, rotors and pads, emergency brake drums. The noise occurs worst at 19-20mph when going straight. Could this be the CV axle?
The noise doesn't change when i have it in 4x4, it slightly weakens when i barely touch the brakes or slow below 20mph. I can't get the wheel spinning fast enough on jack stands to make it make the noise.
Old 03-27-2015, 04:40 PM
RevBiker's Avatar
this maybe dumb, but try removing hub caps then drive it. just an idea?? China front hub/bearings units do go bad fast???
Old 03-27-2015, 04:42 PM
RevBiker's Avatar
see if the noise changes driving like a drunk, turning side to side. If it does then its a bearing.
Quick Reply: Intermittent bringing noise not hubs not brakes
