I bought a plug spitter
1999 Eddie Bauer Expedition. 5.4 shat a plug. I picked it up because it is in amazing shape despite the engine and a low price. I bought a 5553 timesert kit because the hole had been helicoiled before and the 5553 is the bigsert from what I understand. If it doesn't take, it's getting a V10.
Sure wish there was an easy way to throw a 3v V10 in her. I'd be all over that lol.
Nice! It's worth investing in that kit.
Well... #7 repair worked fine, but it's still running terrible. Turns out #4 is dead. I swapped the coil, I replaced the spark plug (actually all of them) I swapped injectors and #4 won't fire. It has injector pulse and the coil will fire when plugged in to the #4 connector. My compression tester doesn't reach down those holes, but that's the only thing left.
A 3v V10 Expy would make a sweet tow rig. I'm sure I could make it propel itself, but passing emissions would be a challenge. I know I'd need to do engine and trans, or standalone transmission controller.
You know, they sound the worst when #4 is the one that's missing. The engines sounds like it blew..more serious than just the coil. Just when #4 is out, they sound exceptionally bad lol.
Make sure that EGR valve isn't stuck open. Just crack it loose and shove a thin steel shim in between the valve and elbow port. Totally block it off. That will save allot of time, horsing around and guess work. That may be enough to kill that cylinder if it wasn't quite up to par to begin with.
Has there been any work done to #4 in the past? Can you tell?
If a 3v dash would fit in my truck, that would be my next project, (a doner vehicle)-after I get this body work finished.
I may do that - but I just don't think there is anything else it could be.
Does the EGR affect #4 more than the others? It's a solid miss and when I pull the injector plug there is no difference at all. Someone was definitely fighting an issue on this Expy. There are 3 brand new coils and the plugs look new - except #7 LOL. One of the new coils was atop #4. #2 injector had a broken pintle cap.
I can definitely hear a light noise on the passenger side which I thought was a plug leaking compression, but it wasn't. I'm hoping it's a lash adjuster or follower like you said. I'll pull the passenger cover and take a peek when I feel like touching this thing again.
On an unrelated note - it's sooooo much easier to hear a difference in idle when pulling injector plugs on the V8 compared to the V10
You could have just lost a follower, they don't always make noises.
Could be a bent valve as well. So you don't have a compression tester? I would have never guessed lol.
I think I'd compression test it before yanking the cover.
I wonder what it would take for the 2 valve v10 to push it up to 400hp 600trq ? Or at least the same numbers as the 3v.
