Battery disconnect - Radio problem?
Hi all,
Serviced my 2003 Harley, but still have the service engine soon light. If I disconnect the battery this should clear (Mustangs used to do this), but I was wondering if I'll have any issues with the radio -- will I need a code to restart it?
Thanks for any help/advice.
Would this work on my 2003 F150? It's harder to find these things in the UK.
Did you get the truck serviced because of the light? If so, then take the truck back and have them resolve the issue.
Any OBDII reader will work, but it will just output a code, and you will have to Google the definition. The high-end ones are able to display definitions and diagnostic info.
How about some indepth info on this!
The PCM needs power to hold it's 'keep alive memory' (KAM) and to hold it's operating tables each time the ignition is shut down.
In addition it holds any codes set in diagnostic memory.
If power is totally removed by battery disconnection, all these tables and info are lost. It only takes less than a minute or two, not 10 minutes or any long time interval.
If your worried about this get a 9 volt battery tool for plugging into the cigar lighter to hold power to KAM if the battery needs to be disconnected for some other reason.
More info: If power is removed from the PCM it causes the loss of code data and stored misfire data and 'zeros' the operating tables back to stock as built, to be rebuilt again from driving cycles.
As far as a diagnostic failure, it depends on what the failure is as to how fast it sets again.
For example a 401 EGR fault code takes two drive cycles to set by design so you cannot say a code will return in 30 miles or any other distance, especially the EVAP system that could take days or weeks depending on the drive cycles and any issue detected.
Lastly, any power removal OR clear function triggers the PCM into full diagnostics such that you must wait for all to complete before the code 1000 clears. The code 1000 never triggers the CEL but only seen with a good Scanner or Reader.
For Radio, only the station memory on the buttons is lost.
The radio has no other main code to worry about.
Good luck.
Good luck.
The first reader I bought didn't work, but the second did. It produced a 0460 code. The fuel sensor error. I wondered if this might be because I have an LPG conversion alongside the fuel tank. Now I know what the code was, I cleared it and it hasn't come on since. I intend to get it looked at regardless.
