'99 F-150 to Lightning conversion...please help!!
Old 07-31-2014, 03:04 PM
tersco6528's Avatar
Just wondering if anyone else has run across this same prob. I have a '99 F150 that i dropped a Lightning long block and supercharger in, changed transmission and the main wiring harness. I swapped the stock fuel pump out with a Walbro 255. I also swapped the factory pcm with a lightning pcm. The truck cranks and runs fine, however, my fuel gauge is always reading a quarter of a tank, except when i cut the truck off. Just wondering if it is on the sending unit end or on the gauge end, and what to do to fix...thanks!!
Old 08-01-2014, 12:02 AM
str8t six's Avatar
did you possibly bend the float when putting the pump back in?
Old 08-01-2014, 08:20 AM
tersco6528's Avatar
I'm not gonna say i didn't, but I don't believe I did. I tried to take extra care not to do that.
Old 08-01-2014, 10:40 AM
illness95's Avatar
same gauge cluster ? and it never did this before ?
Old 08-01-2014, 02:37 PM
tersco6528's Avatar
yeah, its the stock cluster. It never did this until after the conversion, which included the pcm, wiring harness, and the fuel pump
Old 08-02-2014, 11:14 PM
TheBathTub's Avatar
check all your grounds and all other wires to make sure they arent pinched causing some kind of short
Quick Reply: '99 F-150 to Lightning conversion...please help!!
