Dads truck wont start
Hello
My dad has a F150 1999 and he has had this issue a few times in the last month. It just wont start. It cranks but wont fire. He had it towed to his local repair shop and they started it right up. They kept it for a few days and said they checked it over and could not find any thing wrong with it. Started right up for them. They said maybe a fuel pump. It was fine for a few weeks and now its dead in his garage. He takes care of it. Before he dumps 400-500 in a fuel pump does any one here have any suggestions on what to check?
My past experience with fuel pumps they work or don't.
check to see if its getting fuel when it wont start, there are nozzles with valve stems on the fuel rails that you can press the valve stem in and fuel squirts out, if it does then you know the fuel pumps good as you are getting fuel. post the results here and we will be able to help you more after that.
I have asked me to listen for the fuel pump in the past. He always says he has never heard in since he bought the truck new.
When it died in my drive way I messed with it. Swapped out relays, checked all the fuses and nothing. It was dead. I didnt check the fuel rail at the time. Motor was hot hot hot. I never heard the fuel pump be he said neither has he.
His repair shop found nothing wrong and it ran great again for a few weeks. Now its dead again. Not around the corner from me. So I am trying to figure it out before I drop the tank and swap out a pump. Looking for any Fork related items to look for.
Has he tried to cycle the key on and off a few times, ( just to "ON" not all the way to start), then try to start...to see if it will start then?
Is there any dash lights flashing during this "no start condition"?
Did the shop get to use the same Key or the spare key that don't get used too much?
I would have 1st suspected the fuses and relays too...but you mentioned that you swapped them out.
has anybody checked for vacuum leaks?
Did the shop dear ole dad took it too ever test the fuel pressure...curious as to what they found, ( actual readings). Needs to be +30 PSI
I was told they checked it but I dont know any actual readings.
I did when it died in my driveway and nothing.
None Nothing out of the ordinary
Did the shop get to use the same Key or the spare key that don't get used do much?
They used the same key. I have messed with it with both keys he has.
I don't know if the shop did. I have not yet.
90 percent chaance its the fuel pump. Slim chance its something else. All that has to be done is checking the pumps operation during the no start the wat everyone already said. If it wwere me I'd just order a pump and eliminate that because there is a very high probability thats the issue.
