torn rubber hose stuck around spark plug.
Old 01-24-2012, 10:27 PM
NickArellano97's Avatar
Does anyone know the best way to get what looks like a piece of rubber hose stuck around the spark plug in cylinder #4 which has very little room to work.
My teacher for auto tech said to lift up the fuel rail, remove injector #4 to get more room. and maybe take off the heater hoses for even more room. (he did look at it)
I was going to do a compression test but cant until that last spark plug is out.
I have like a little hook connected to a handle, and long needle nose pliers that will reach in the spark plug tube. but cant get that rubber hose out of there.
do y'all guys think I should remove the injector and heater hoses for more room. or what? Thanks
Old 01-24-2012, 10:46 PM
BOOMER2011's Avatar
get a pair of straight nose hemostats from a medical supply store, best 2$ investment i ever made for a pair of 19" super needle nose pliers hahah they look like this:
Old 01-25-2012, 12:26 AM
Toyz's Avatar
Or a pick set, like teeth cleaning pick looking things to pick it apart and suck out or blow out the debri before removing the plug.
Old 01-25-2012, 01:24 PM
Ill try blowing it out first see if that does anything if not Ill be looking for some pliers like boomer2011 said but longer. thanks guys
Old 01-26-2012, 03:40 PM
got the piece of rubber hose out. I used air but it didnt work, so I moved one of the heater hoses and used a zip tie to hold it out of the way. then unbolted th right side of the fuel rail and pulled it up, and took off #4 fuel injector, then unbolted the battery fuse bracket from the firewall and pulled it forward. I used a small hook with a handle to get it out. it took about 2hr-2.5hrs to do all of that.
Old 01-26-2012, 03:51 PM
BOOMER2011's Avatar
And that is why I love hemostats haha
Glad you got it out
Old 01-26-2012, 03:52 PM
Rubber hose?
Did part of the cop boot get stuck in the plug well?
Old 01-26-2012, 04:01 PM
Originally Posted by 88racing
Rubber hose?
That is what I am wondering.
Old 01-26-2012, 04:44 PM
what school? (Just curious)
Old 01-26-2012, 04:59 PM
enriched's Avatar
is the plug well too small for a ExActo knife to reach in and cut it? er a very sharp small knife.
Quick Reply: torn rubber hose stuck around spark plug.
