Changed to a lightning instrument cluster and now it won't start. THEFT??!??
all 99+ f150's have PATS. Troyer can turn off pats. The reason he says he can't is BS. That is Mike troyer being Mike Troyer. You don't need to get a whole new ignition that is the dealer trying to up sell. I would be leary about them reprogramming it because you may lose your custom tuning. Call another tuner and ask if you can send a copy of your tuning and get them to take the pats out.
with a flash from the dealer there is at least a 95% chance you will have a different stategy. You would need to start tuning from scratch again
Return your truck to stock program and get your keys programmed into the Pats system. The keys with the black cover are basically a key fob. Kinda like access controls on a building I.E. access cards. It takes about 5 minutes tops to program two keys. The dealer has a handy dandy tool that plugs into the obdII port. They program each key and test to make sure they both start the truck. Ask me how I know....lol
I would never disable PATS. Without that any schmuck with 2 braincells could hotwire and be off with all your hard work.
Well I just got it back from the dealer, it starts now but the speedo won't budge off 0 and the tach is choppy. Getting frustrated. The odometer still reads 130k so maybe they just need to do more programming? To their defense I did just tell them to get it running. I was worried about them screwing up the tune. But I assumed the speedo would work.
What your not informed about is some of the following.
The dash 'marries' to the computer by code and is why there is so much hassle in the change over attempt.
The PCM has a word in program that has 'bits' set to indicate what options there are in the original build.
There is communications between the PATS and the PCM via a seperate bus pair.
If this fails for any reason the ignition and fuel is prevented from working.
The dash speedo, tach and mileage indicators get there information from the PCM in digital code.
You got yourself into a hassle by not knowing what all is involved in different areas.
It's a full computer system you just cannot change parts of without getting into an involved process by some one who understands and is abe to do/ make changes.
Good luck.
Good luck.
Good luck.
Good luck.
Good luck.
Good luck.
