Heater core bypass
Heater core bypass
Anyone have a write up about a heater core bypass? I have a strong scent of coolant in my cab, and am also leaking it, so pretty much guessing the core has bit the dust. Local shop quoted $800 for labor. So I'm thinking I'll just buy the $100 new heater core and do it myself with the writeup from here. But in the mean time, I heard you can bypass the broken one until you replace it.
So if anyone has a write up, or instruction how, that'd help greatly.
Also, is bypassing the heater core gonna mess anything up in the long run if it takes me a while until I can get it swapped out?
on
I have replaced so many on my truck, 8 or 9, that I no longer use the quick disconnects. I have 5/8 hose over the pipes and I keep them extra long. I have the T fittings used for coolant flushes plumbed into the lines. When the core goes I disconnect the Ts and use 1 of them for a connector.
