4x4 engaging by itself (at random not good)
#106
Hey guys, got a call back from my mechanic, after much testing he determined the problem is within the GEM itself. THere was zero fault codes for the shift motor or the dash switch. He believes it is internally corrupted and basically thinking that the dash switch is being moved and it is seeing a request to shift. So part# F85Z-14B205-NA is going to be ordered, best he can do for me is $250
I was hoping this module would have worked! bout $100 cheaper!
http://cgi.ebay.com/ebaymotors/ws/eB...K%3AMEWAX%3AIT
#108
I hope its the end of this fiasco!
I don't know if my tech fixed it or not, may have not noticed it and I failed to remember, but what do I do for the light in the dash switch? Is there a fuse I should check for it first? Can I even get a bulb for it?
Thanks JMC, this has been a valuable learning experience!
#111
Hey F150bryan, YEP! I just got truck back tonite, all 4x4 operations are a GO. My mech pointed out to me the corrosion on the back of the GEM board. I overlooked it before, it is soo minimal but once you look for it, it starts jumping out at you. He charged my $240 for a new GEM. I thought that was pretty good and $100 labor so $340 for everything. It was worth it, I was pulling my hair out at the end! I'll have to get some pics up for you guys of the corrosion.
He told me probably because my truck is extremely low mileage (40K on the clock) the GEM just got condensation in it from sitting around, truck not getting drove much, lots of heat/cold cycles throughout the years and not a ton of air movement didn't help.
#112
#114
#117
4X4 engaging by itself
Same thing was happening to me. Riding along and the 4X4 light comes on and you here the cluck. I seen other posts and found that it really didn't go into the detail. So I added this.
Didn't touch anything and pulled the transfer case switch motor and found the post under was pointing to 2wd (switch was in 2WD). This was weird because the relay at the front by the battery for 4X4 was on(had vacuum). There are two relays the one closest to passenger side is 4X4 and the other is 2wd. One of them is always on. So the clunk is from the front engaging the hubs, but the transfer case never switched. I pulled the motor and left it hooked up to the truck. I moved the switch to all three positions and it didn't move at all. I pulled the motor completely and put 12V on the bigger yellow and orange wires and it moved in both directions fine .
This led me down other paths because turning the switch I didn't hear the relays clicking. In other posts talk about bad PCM or switch. I ohmed the switch and found it was fine (pins 2 and 3. 3.8k 2wd 1.06k 4hi).
I seen the price for a new or used PCM. Ouch.
Because I am cheap and figured it doesn't take long to put in I changed the motor even though the old one moved, maybe the feed back switches in the motor was bad.
Wallah new transfer motor it starts working.
#118
THE PCM HAS ......NO-NO-NO...……….. CONTROL OF THE 4WHEEL DRIVE FUNCTION.
The PCM is engine control and transmission normal gear shifting only.
The GEM, at the request of the dash switch, controls all the 4x4 functions.
The transfer case and 4x4 functions are totally separate.
There is no basic vacuum control except for the front axle actuator AFTER the case motor runs to first position.
A random 4wd engagement is a false operation of the GEM.
Very often it is corrosion inside the GEM on the circuit board. The GEM is located behind the dash fuse panel and can get wet from a leaking wind shield or cowl seal.
The case motor cannot operate unless the relays that are controlled by the GEM operate them thus the motor.
#120
4x4 randomly engaging
Hey folks, its been awhile! (My truck has been so good to me) Up until today!
Well I was driving down the road and all the sudden clicking in the dash faster click click click click click and the 4x4hi light is going on and off and I can feel the 4x4 engaging (this is around 55MPH) So I make my way back home after messing with the ESOF switch on the dash and it eventually behaves, kicks into 2wd and I get home. I checked everything, all vac lines, took apart connector on transfer case motor, blew out with compressed air, snapped bakc together all nice and dry.
It will work normally in the driveway but for some reason up to speed on highway (vibration issue?) It randomly shifts into 4x4 hi when it feels like it.
Mechanic friend told me mostly likely either transfer case motor (looks rusty and possibly cracked on housing were wires go in) or its the dash switch ****. I asked him about GEM (where the heck is that) and/or vac lines, he said if it engages normally sometimes its not VAC its def. electrical, he said GEM is only culprit if you have a water issue with leaking windshield/etc.
Anyone experienced this "phantom" 4x4 shifting?
Thanks for any input!
