How To: Replace auto shifter boot
on
I replaced my torn auto shift lever boot (Part # XL3Z-3D677-AAB) the other day, so I snapped a few pics and wrote a how-to of this simple repair. I'm not sure how common this problem is (I found little info searching), but the boots have torn on both my truck and my work truck ... possibly because I drive with the wheel tilted all the way down and the upper steering column cover may be rubbing up against the boot.
The repair consists of removing the upper steering column cover and the shift lever to install the new boot.
1. Disconnect neg battery cable.
2. Remove the steering column opening cover.
3. I removed the lower instrument panel steering column cover to make it easier to get to the OD wires/plug. While not necessary to complete the repair, I think removing the cover makes it easier (you can also take this opportunity to easily adjust your dash gear indicator, if necessary ).
4. Remove ignition switch lock cylinder
5. Remove 3 screws (Philips) and remove the upper steering column cover.
6. Unplug OD wire by following the wire from the shift lever to the plug under the dash, just left of the steering column. Remove the OD wire from 3 clips, and pull it up out of the dash.
7. Remove old shifter boot from steering column and shift lever.
8. Drive out pin holding shift lever and remove shift lever.
9. Remove old shifter boot and carefully slide new boot over OD wire connector, down the wire and onto the lever. Push frame of boot onto/into pin/slot on the steering column. Make sure the boot is oriented properly on the shift lever so when the boot and shift lever are installed, the boot is not twisted.
10. Follow removal procedure in reverse order.
Note: My Ford service manual calls for a new shift lever pin whenever the shift lever is removed. I reused my old pin ... you can do what you wish
- Move shift lever to 1
- Pull up clips from bottom of cover first
- Remove fuse panel cover
- Remove unused gray electrical connector from the lower instrument panel cover
- Remove 2 screws (7mm) holding hood release lever
- Remove 2 screws (7mm) holding parking brake release lever
- Remove 6 screws (2 - 8mm, 4 - 7mm) holding lower instrument panel cover
- Remove lower instrument panel cover
- Turn the ignition to RUN position
- Insert a thin punch into hole in bottom of steering column cover to push the release pin.
- Pull out the ignition switch lock cylinder while pushing in the release pin
i know which bolt you are talking about and you can not see it from any of these pictures. If it's the torques bolt i am thinking of it goes straight up under the dash you wont have to remove any panels or anything to get at it. its way up there and to find it jiggle the shifter around. you should see where it pivets and there will be a plate there where the bolt threads towards the rear of the truck. you need to get that bolt in there before the truck wont start because the neutral safety switch is not reading that the truck is firmly in park. it's hard to explain where it is but super easy to do.
