Starter will not disengage
I just replaced my starter because it went dead. I am now assuming it went dead because the solenoid on the starter burned up. I say this because now that I have installed my third new starter, it always stays engaged after starting the engine.
The mystery here is that I have done "ALL" of what I think is the obvious.
1. Replaced Starter.
2. Replaced Starter switch (Switch/Relay that is mounted on the firewall)
3. Battery is fully charged.
4. Replaced Ignition Switch
5. Snipped end of ground wire and reattached new clean connector for bolting to 3rd (bottom) bolt on starter for grounding.
Any help would be greatly appreciated.
Thanks in advance!!
Thanks in advance!!
glad you got it fixed i had the same problem one time fried 3 starters before i seen my brother had it hooked up wroung. its easy to do when your in a hurry to get your ride back on the road. people on this site will help you with anything they are good people welcome aboard.and give back if you can help someone with a problem.
Huh, I've never done that one. My truck has cranked over before , when I was washing it. Thought it was possessed lol. I had a hole in the cable insulation and my harness was holding water.
Hi 2001 F150 XLT 5.4L here ,im having the same issue ive been through 4 starters and they all would not disengage. I believe im hooking the wires up right? theres a solid black cable that I put on the starter solenoid. the small red wire I put on the th small terminal and theres the kinda big 2 wires on a metal connector that you use to ground on the bottom bolt or stud. Am I wiring it up right guys?
That's what im asking. I put the small red wire on the small terminal on the starter solenoid. the I put the big black one on the larger terminal post across from the terminal with the thin piece of metal going to the starter motor. Then theres another black cable down there it looks like two black cables but theyre connected at the end on a metal connector/washer looking thing. And when I originally took the 1st starter off that wire was on the bottom stud bolt and had two nut on it.
You're the man!!! your post got me straightened out .... thank goodness ... after only one starter. That top bolt is a BEAST!!!!
2000 Ford F150 XL 4x4 4.2L V6
]I just replaced my starter because it went dead. I am now assuming it went dead because the solenoid on the starter burned up. I say this because now that I have installed my third new starter, it always stays engaged after starting the engine.
Thanks in advance!
Thanks in advance!
The starter can't remain engaged if you put the cables back where they belong.
What you have now is once the start relay pulls up the mis wiring hold it up and keeps the starter connected to the battery.
The firewall relay should only be controlled by the ignition switch in start position
That circuit runs through the transmission selector in PARK and Neutral only..
Take a look at another truck's wiring if your not sure or take the leads off and ID the ignition lead with a voltmeter and put it on the correct terminal.
Good luck.
Good luck.
Thanks in advance!
Thanks in advance!
