XL F150 doorpanel removal
on
- Pull off the plastic trim running up behind the window to expose a screw holding the top of the door panel
- Remove cover from around door handle to expose a screw holding the door panel at this location
- Slide cover over on window crank to expose torx screw holding handle on
- Lift door panel to remove
on
I was just getting ready to click post reply, when I saw the above post
Some pics from when I replaced my mirrors ...
Remove cover from around door handle ...
... to expose a screw holding the door panel at this location
It can be a little tricky getting the lock tab lined up w/ the slot in the door panel when putting it all back together, but other than that, it's pretty basic.
well i got um on today it was actually quite simple once i fugured out what i was doing but realized on thw window crank i didnt have a torx screwdriver cause we just moved, i went to wal-mart and got a bit set and had to rig it on an wrench cause the hole was so small. Took a while for that but it was easy after that, second door i was finished in like 15 min. I got the chrome was btw.
