Side Mirror broken glass replacement?
2001 Ford F-150 XLT, Non-heated, Power mirror. Chrome housing. Driver's side.
My mirror is cracked down the center? On previous vehicles I have owned I had to replace the whole housing not just the glass. What's the easiest fix?
Local junkyard has a few computable. F-150s.
The glass on my drivers side is broke. i like it. adds character
I ordered an entire new mirror for my passenger side for about 30 bucks. So far its just as durable and as good of quality as the original. Ordered from usautoparts .net. Real easy to install. Just pull the door panel and its just 3 nuts
be real gentle putting the new glass in if you go that route. thats how i cracked my drivers side mirror
on
I've seen new glass on ebay for pretty cheap ... no idea if they're any good or not. You can also get used factory mirrors on ebay for approx $30 ea shipped. I would stay away from the Chinese aftermarket replacement mirrors ... the set I got were total trash (didn't fit very good and shook like mad when driving).
Wow, This is an awesome board, with very helpful and knowledge members love it!
I'm going to swing by the local auto parts store today, order one up.
How do I go about removing the old and adding the new? What part of the actual housing pops off? Do I have to remove the whole housing?
Thanks!
Thanks!
just go to the junk yard with a screw driver, (may not even need that) and pop one out. make sure that it has two pins that have threads on them and two that are smoth, the expys and lincolns that i have seen are different so try to find a 150. then yours comes out the same way. then line up the pins of the new mirror, and squeeze the center. i thought i was gonna break mine when i did it, but i just had to pop it with my palm really hard and it popped in. (there is a little ball in the center where the mirror pivots) cost maybe 5 bucks and 20 minutes worth of work.
I assumed it was somehow glued and screwed and I would have to take the whole unit off the truck to replace the mirror somehow?
