Canister Vent Solenoid YL5A-9F945-AA
Hi
Please help me find this part.
I need to replace the canister vent solenoid. The one I removed from the truck is the original. The number on the part is YL5A-9F945-AA.
I don't see it on the internet anywhere.
Where can I get one?
Harry
2002 F-150
4.2 L
Manuel Trans
Harry
2002 F-150
4.2 L
Manuel Trans
Is this what you are looking for? Vapor Canister Purge Solenoid
http://www.rockauto.com/catalog/moreinfo.php?pk=945934
Airtex part # 2N1123, $46.89 plus shipping.
You can get it at the dealer. Not expensive at all. But do make sure that is the problem. What was your engine code? Awhile back I ran into some trouble that pointed to the canister vent solenoid but after I replaced it I learned that it was an electrical fault. Follow the two wires from the solenoid to the wire harness, I bet at the frame rail the wire has split open, as it tends to rub the frame rail.
Hi
I found one at the dealer and put it on this am.
I still have code p0455 EVAP Emission Contol System Leak (Large).
The 2 wires seem ok into the wire harness.
When the service engine soon light came on I bought a fuel cap.
Any suggestions?
I want to avoid a rape job at the dealer if I can avoid it.
Harry
2002 F-150 XLT
4.2 engine
Any suggestions?
Harry
2002 F-150 XLT
4.2 engine
P0455
Hi
UPDATE - after 300 miles no codes or service engine soon light....knocking on wood.
Apparently the Vapor Management Valve part #9C915 was inop (stuck closed). I bought the new Motorcraft on Amazon for $33.79.
The valve part of the canister vent solenoid (located beside the canister) was full of fine dust so I'm glad I replaced it....and the gas cap was original 2002.....so I'm glad I replaced that as well.
Harry
2002 F-150 XLT
4.2 engine
Harry
2002 F-150 XLT
4.2 engine
