ECU swap ?
ECU swap ?
Hello - ( new in here )
I have perfectly good running 97 f150 4.6
But wanted more power - so went and bought edge
everything reads out fine - but cannot program power setting or anything else in there.
So went to local dealer to upgrade the ecu firmware - and dealer could not do it - and something about memory error and ecu has to be replaced.
talked to edge and they came up with nothing.
Whell - to come back to original question - can i just get ecu from ebay and just swap it with mine ?
Just on the 99+ because of the PATS. The 97-98 ones you can just swap pcm's. Just make sure you get one with 4.6 and whatever tranny you have. You may have to get one from a 97-98 but I don't know if there is any security feature in the pcm itself or you may be able to use one from 97-00.
It also says that you need vin reprogramming for the escort zx2 and I had half a dozen didn't pcms in that car without taking it to the dealer, its just plug and play. It also has the mechanical speedo and no pats just like the 97-98 f150's.
For sure any pcm from 97-98 with the same tranny and the 4.6 motor will work just plug and play.
Doesn't matter the code either, whether axp2, mfr4, whatever the hell they have for those pcm codes.
one from a 99-00 MAY work, big emphasis on MAY, but I do not know how the PATS system works with the pcm, on the newer models
did not check for code - just bought used ECU and swapped today and it works
And now i CAN program power settings from Edge ( alltough i still cannot change tire size
because it's not compatible with my car type ?!? )
Also another interesting thing is my previous ECU -it has some black metal box
attached to bottom of the ECU .... seems just like expansion card ?
what is it ?
on
You are THE MEN - you were right
what is it ?
what is it ?
